Siphon Transmission Fluid And Replace With A Few Qts
198,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ROBERT CLARK2
  • 21 POSTS
I can't afford a full change but it's brown. so can I siphon a few qts and replace it with no problems until incandescent change it. More like a temporary bandage for now.
Jun 18, 2023 at 1:59 AM
  • 110,244 POSTS
If you are able to draw it out via the dipstick tube, yes, it won't hurt. However, I'm not sure if you will be able to get enough out. Maybe 2 or 3 quarts would likely be as much as you can draw out. Is that what you expected? Also, you will need a vacuum source to draw the fluid out.
joe
Jun 18, 2023 at 3:21 PM
