convert to rear wheel drive
2008 TOYOTA COROLLA
16,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
MUHAMMED ALI BUTT
Hi sir, is it possible to convert Toyota corolla engine to rear wheel drive the engine which is in Toyota corolla drives front wheel? Can we take that engine and convert it to rear wheel drive and plant that engine in mid engine layout is that swap is possible? do every front wheel drive car engine be converted to rear wheel drive because the basic object of engine is to give power but it depends on manufacturer to give it front rear or all wheel drive? Can all front wheel drive engines like Toyota, Nissan and Honda engines can be converted to rear wheel drive waiting? Thanks.
Jul 9, 2016 at 9:44 PM
HMAC300
  • 48,601 POSTS
if you have a ton of money you can convert to rear wheel drive, but not sure if anything is available to do this as well as all wheel drive. there may also be a space problem under hood as well.
Jul 10, 2016 at 1:40 AM
