Engine will not stay running and Cam sensor reading is zero
160,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
DAN MARTINDALE
I've been having trouble with my vehicle starting and then immediately stalling. When i do a live scan i notice that the cam sensors are all doing counts, but it shows cam sensor RPM at zero. I think the problem may be there which is probably affecting timing.
What is the most logical cause of this? I am getting zero codes but show a very lean mixture of 29.3:1 command ratio and about a .9 equivalence ratio. Thanks for your time.
Jan 6, 2022 at 1:06 AM
  • 110,248 POSTS
The idea that it is running lean can be the result of low fuel pressure or an engine vacuum leak. Have you checked either of those at this point?
Also, did you check for a crankshaft positions sensor signal? That can prevent an RPM signal. However, I wouldn't even think it would start without either providing a signal.
Jan 6, 2022 at 9:19 AM
