cannot seem to get the computer to give the fault code?
1995 NISSAN TRUCK
180,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
TINYLIMO
I turn on the key, turn the switch to the diagnostic mode, one, blink, two blink, three blink, four blink, then turn the switch back and wait, and wait, and nothing happens, disconnected the battery for three minutes to reset the computer, it did not reset. Removed the battery for the night to see it that works. The truck has been sitting for 6 year had to replace the fuel pump assembly to get it to run , runs great drove it about 150 miles. Just need to know what the check engine light is doing on. Is there an OBD, OBD1 code reader that I can use?? You have to be in computer mode three to read codes then tun off the switch and it works the instructions were wrong or for a different computer.
Jun 18, 2023 at 10:02 AM
  • 55,214 POSTS
There is no reader for this truck, you must follow this guide to get the codes:
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
Please go over these guides and get back to us.
Jun 19, 2023 at 11:24 AM
TINYLIMO
I managed to get it to work but erased the codes by accident, so it blinked 5 and 5 but I retrieve the codes in mode three, mode four never did anything.
Jun 20, 2023 at 9:11 AM
  • 55,214 POSTS
Code 55 No malfunction recorded, so you will need to drive it to show the code has a chance to show back up again.
Jun 21, 2023 at 2:50 AM
TINYLIMO
yes, will see what happens have to get it inspected should be ok we do not have emission test if it is 20 years old or older.
Jun 21, 2023 at 6:11 AM
  • 55,214 POSTS
Sounds good, let me know if you need any more help.
Jun 23, 2023 at 2:43 AM
