CAN NOT GET AC OFF BUTTON LIGHT TO GO OFF NO AC AIR
Apr 19, 2014 at 4:42 AM
✓Experienced Mechanic
You first need to check that the A/'C system is full of refrigerant and the system pressures are correct, do not just add refrigerant to the system as this will cause more problems if not done correctly and if the system is over charged.
