What is the part number for the end of the bypass pipe (between thermostat and water pump?
165,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
HOWIE_REY
The end of the bypass pipe (between thermostat and water pump) on my d15 Honda Civic ek3 has rotted off and water is flowing out pass the O ring. What is the part number for its replacement as I am seeing more than one?
May 24, 2025 at 8:04 AM
  • 55,711 POSTS
Sure here is are the parts numbers
Manual Transmission: The OEM part number is 19505-P2A-000.
Automatic Transmission: The OEM part number is 19505-P2J-J60.
Let us know if you need anything else.
May 25, 2025 at 5:30 AM
HOWIE_REY
Thanks for the quick response, much appreciated. I am in Jamaica and I doubt anyone has this part new, so I am looking to buy it used. Is there a part number for the seals/O rings as well?
May 25, 2025 at 6:29 AM
