Can low oil cause my car to over rev when accelerating
2003 FORD FIESTA
149,000 MILES • 1.2L • 2WD • MANUAL
NOBLE1991
When I accelerate to but speed, for example merging onto the motor way or even after changing gear. There’s also a knowing sound. I’ve Googled it and all the symptoms point to an oil issue.
Oct 11, 2019 at 6:44 PM
SCGRANTURISMO
  • 4,897 POSTS
No. Having low oil will not cause your engine to over rev, but it can do catastrophic damage to your engine's bearings. the bearings in your vehicle's engine depend on a thin film of oil to lubricate the rotating parts against wear. The easiest way to check the oil level in your vehicle is to pull the engine oil dipstick, wipe it clean, reinsert into the dipstick tube all the way, pull it out again and check the level of the oil. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Oct 12, 2019 at 3:24 AM
