can i use a v6 2.5L engine to replace my 4 cylinder 2.0L?
180,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
LACHYTOON
  • 21 POSTS
i have a 96 dodge avenger 4 cylinder 2.0L the car runs fine but the engine its not powerful enough i'm thinking about using a v6 2.5L from another avenger .Is that posible?
Jul 23, 2014 at 8:35 AM
  • 110,248 POSTS
Anything is possible, but I wouldn't recommend it. The cost will be more than the vehicle is worth. Everything needs changed, computers, sensors, wiring harnesses, vacuum harnesses, the trans won't work properly with the new PCM... I hate to say it, but I don't recommend it.
Jul 23, 2014 at 12:42 PM
