Can I torque the cam sprockets while the belt is on?
2004 ACURA MDX
210,000 MILES • 6 CYL • AUTOMATIC
ALICIA RAYMOND
I forgot to torque both the rear and front cam sprockets down, do I have to remove the entire timing belt? I am worried it will move one gear and throw everything off. Please help.
Mar 30, 2023 at 12:53 AM
  • 55,423 POSTS
I would not rely on the timing belt to hold the gear while you tighten it, you might be able to hold the camshaft once you remove the valve covers, did you replace the camshaft seals is that why the gear was removed? Sometimes the camshafts have flat spots you can install a wrench onto to hold the cams while tightening. Can I ask how you got the gear removed from the camshaft? Please let me know.
Mar 30, 2023 at 7:07 AM
