Need a new transmission found a used 4r70e from a two wheel drive, but i have a 4r75e four wheel drive.
Oct 22, 2016 at 4:46 AM
✓Experienced Mechanic
If everything looks the same wiring connectors etc you should be okay just remove the tail housing and swap it over, here is a video of a transmission removal on a similar car, the procedure is the same.
