Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Marquis
Drivetrain
Transmission
can I put transmission from 2004 crown victoria in 2003 grand msrquis ls?
2003 MERCURY MARQUIS
110,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
1BADMERC
MEMBER
Same transmission different order numbers
Apr 23, 2015 at 9:12 PM
HMAC300
Experienced Mechanic
shold be able to they are both obd2 that is important part
Apr 24, 2015 at 12:30 AM
1BADMERC
MEMBER
Yes but the secondary codes are different. 3w7p7000be and 4w7p7000be.
Apr 24, 2015 at 12:50 AM
1BADMERC
MEMBER
Correction 3w7p7000be and 4w7p7000ea.
Apr 24, 2015 at 12:53 AM
HMAC300
that is for production. see pic
Image (Click to enlarge)
Apr 24, 2015 at 1:03 AM
1BADMERC
MEMBER
So I should be good to go?
Apr 24, 2015 at 1:26 AM
HMAC300
yes the numbers you se on what I sent is just an example it should be fine
Apr 24, 2015 at 1:40 AM
1BADMERC
MEMBER
Thank you so much for the help.
Apr 24, 2015 at 1:47 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
