Cigarette lighter fuse keeps blowing
175,000 MILES
JAVON32
Can I be using the wrong lighter for my socket cause it blow the fuse. But if I plug in a car charger it doesn't blow the fuse.
Apr 3, 2020 at 8:15 AM
If it fits in the outlet then it is most likely not the wrong lighter. It is most likely shorted and it draws too much current. That is what blows a fuse is when a load in circuit is drawing too much current. So it appears the lighter itself is the issue if a charger doesn't blow the fuse. I would just go ahead and replace the lighter.
Let me know if you have questions. Thanks
Apr 3, 2020 at 8:39 AM
JAVON32
Apr 3, 2020 at 8:54 AM
You are welcome. Please come back to 2CarPros if you need info about anything else. Thanks
Apr 4, 2020 at 2:06 AM
