Can I be using the wrong lighter for my socket cause it blow the fuse. But if I plug in a car charger it doesn't blow the fuse.
Apr 3, 2020 at 8:15 AM
✓Experienced Mechanic
If it fits in the outlet then it is most likely not the wrong lighter. It is most likely shorted and it draws too much current. That is what blows a fuse is when a load in circuit is drawing too much current. So it appears the lighter itself is the issue if a charger doesn't blow the fuse. I would just go ahead and replace the lighter.
Let me know if you have questions. Thanks
Apr 3, 2020 at 8:39 AM
JAVON32
MEMBER
Apr 3, 2020 at 8:54 AM
You are welcome. Please come back to 2CarPros if you need info about anything else. Thanks
