A/C and electrical issues
200,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
DERTY
  • 8 POSTS
While I’m driving an have my A/C on all of the lights on my dashboard come on, all of my gauges go down except for speedometer. while that is happening? my A/C stops blowing cold and I can’t let my windows up or down! But when the gauges move back into there place everything starts back working! What is the problem? Any suggestions?
Jul 9, 2019 at 12:24 PM
Good morning,
When the AC is off, does any of this happen?
Can you upload a video of what happens?
Jul 10, 2019 at 12:37 AM
DERTY
  • 8 POSTS
Okay.
Jul 11, 2019 at 7:29 AM
Okay, again, does the truck work normal when the AC is not on?
Jul 11, 2019 at 7:31 AM
DERTY
  • 8 POSTS
Yes.
Jul 11, 2019 at 8:13 AM
DERTY
  • 8 POSTS
It still drives fine.
Okay. The only thing they have in common is the body control module.
Can you monitor that with your scan tool?
Jul 11, 2019 at 8:22 AM
DERTY
  • 8 POSTS
I don’t have one.
Jul 11, 2019 at 8:38 AM
At this point, you need a scan tool to see what the BCM is doing. It may have corrupted software and need to be reprogrammed.
Jul 11, 2019 at 8:40 AM
I see you responded but nothing came through.
Jul 11, 2019 at 8:47 AM
DERTY
  • 8 POSTS
I don’t have a tool to do that. can they do it at AutoZone?
Jul 11, 2019 at 8:55 AM
You would have to call and check. It depends on the store what scan tool they use.
Jul 11, 2019 at 9:03 AM
DERTY
  • 8 POSTS
Okay, and what scan tool should they have?
Jul 11, 2019 at 9:26 AM
Something that will read the body control module live data.
Jul 11, 2019 at 9:32 AM
