Can a relay stop my car from starting
169,000 MILES • AUTOMATIC
JODY WAYNE HODGE
Battery is good, starter is good and alternator i s good. What next?
Apr 13, 2017 at 11:37 PM
STEVE W.
  • 15,409 POSTS
Sure can. So could a bad ignition switch, neutral range switch or wiring in between.
Grab a test light and a wiring diagram for your vehicle and follow the power from the battery to the starter. Where the power stops check the component in between the battery and that point.
Apr 14, 2017 at 12:08 AM
