Can a problem with starter cause battery light to come on
2004 MERCURY MOUNTAINEER
100,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
CATR
About six months ago my battery light started flickering very rapidly suddenly. I stopped and had the battery, alternator and starter tested and the person said my starter was fine but wasn't able to test the alternator or battery for some reason. I light went off for two months and suddenly started flickering again for a little bit off and on for about a week then had to be jumped started to start it. I replaced the battery and no issues again until now, three months later from replacing the battery. The light started flickering again. So I just bought an alternator thinking it's that even though the light has stopped again. I haven't had the opportunity to put the alternator in yet but my starter just stopped working today. I know that as when I turned the key there was power but wouldn't even try to start. I tapped the starter and had some one key turning the key until it started. My question is, can the flickering light be from the starter or should I also replace my alternator too?
Feb 20, 2019 at 2:00 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes, you probably have a "dead" spot in your starter. The fact that your starter wouldn't turn until you tapped it with a hammer is a pretty clear indication of that. I have included a few links below. They are guides that troubleshoot your vehicles starting/charging system. Please go through them and get back to us with what you find out.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Thanks,
Alex
2CarPros
Feb 20, 2019 at 2:20 PM
