Can a front wheel bearing be replaced or does the whole hub assembly?
1995 TOYOTA CELICA
285,523 MILES • 1.8L • 2WD • MANUAL
KATIEISREBEL
  • 27 POSTS
My right front tire is making that tell-tale annoying noise that indicates a wheel bearing is functioning on borrowed time. I went to parts store and got an inside wheel bearing, but then it dawned on me that the hub and bearing may be all one unit? I don't think the guys at the auto parts place would have sold be just the bearing if that was the case, but on the off chance they would I wanted to ask a source I trust, and you guys have helped me countless times and I trust the advice and know-how you provide.
Dec 13, 2021 at 5:58 AM
  • 110,244 POSTS
The front wheel bearing is in the steering knuckle and is replaceable. You don't have to purchase an entire hub.
If you look at pic 1 below, I highlighted the parts that will be removed, inspected, and replaced with new parts.
The remaining pics are the procedures for removal and replacement. Take a look through them and let me know if you have questions or if there is something I can help with
Dec 13, 2021 at 8:59 AM
KATIEISREBEL
  • 27 POSTS
Thank you so much!! You guys are awesome and have never failed to help me any time I have a new mechanic-type issue!! I have learned just to go straight to you guys when I am facing a new challenge since most people doubt my capabilities because I am girl and don't think I can do it. Well, because of the help I have gotten through this website, i have successfully fixed a number of things on my cars over the years, including replacing a timing belt! So, thanks!! You are appreciated.
Dec 13, 2021 at 12:12 PM
  • 110,244 POSTS
You are very welcome. Please let me know if there is anything I can do to help.
Dec 14, 2021 at 9:06 AM
