Camshaft timing
480,000 MILES • 1.6L • 4 CYL • 4WD • MANUAL
TARRI
I would like to set camshaft timing with no marking on a pulley. how do I set it?
Oct 16, 2021 at 2:22 AM
  • 110,248 POSTS
There are no timing marks for the camshafts. Fiat requires the use of a special tool that locks to the rear of the camshafts.
Please keep in mind, this is an interference engine. If timing is off, it can cause internal engine damage.
I attached two pics below. The first shows the camshaft positioning and the second is a pic I found online showing the tool needed.
I hope this helps. See if you can rent the tool. I wouldn't recommend doing it without one.
Oct 16, 2021 at 3:33 PM
TARRI
Thanks Joe, much appreciated. First picture for camshaft positions is blank could you resend please?
Oct 17, 2021 at 3:00 AM
  • 110,248 POSTS
That's interesting. Let me know if you get it.
Oct 17, 2021 at 1:28 PM
TARRI
Thanks, I've got it. it's so interesting because on the picture there's marking but not on the original pulley.
Oct 17, 2021 at 6:31 PM
  • 110,248 POSTS
At times, I believe they do things like that to make it a little more difficult for people to work on. If you get the tool, it should only fit one way, so you'll know it's right.
When you get it back together, turn the engine by hand several revolutions to make sure there is no internal interference between the pistons and valves. If it stops turning, don't force it.
Take care. If you have a chance, let me know how things turn out for you.
Oct 18, 2021 at 10:04 AM
TARRI
Much appreciated .I'll let you know.
Oct 18, 2021 at 9:30 PM
