Camshaft sensor replacement
110,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RIVIPEPE1234
If I replace the sensors myself, is it possible to not have to relearn the system? Can the cars computer do it on its own?
Feb 4, 2021 at 12:01 AM
SEVAG P
  • 405 POSTS
hello,
Camshaft sensor replacement does not need any relearn procedure, just remove and reinstall.
check the figure 1 and 2 below procedure how to replace inlet and exhaust camshaft sensor.
check figure 3 and 5 location of the sensors.
let us know if you need more help.
thank you.
Feb 4, 2021 at 12:53 AM
