Can I get a diagram to remove the camshaft bracket?
165,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
CONFOS95
I need a diagram to remove the camshaft bracket. I have removed the 2 bolts but can not find what else to remove to be accessible to the sensor.
May 30, 2023 at 2:54 AM
  • 55,711 POSTS
I am not sure about the bracket you speak of, can you upload an image or short video? Here are the instructions on how to change out the camshaft but you will need to remove the cylinder heads first. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 12:08 PM
CONFOS95
Thank you Ken for all the info unfortunately I reread my question and forgot one important word. Sensor. Camshaft sensor. Im sorry for the mix up. My brain has been working to hard trying to figure this out. The 2 bolts on the metal bracket that hold the camshaft sensor harness have been removed. Is there another bolt behind the harmonic balancer that I just can't see?
Thanks again Ken
May 30, 2023 at 12:25 PM
  • 55,711 POSTS
No problem. Please post your new question here, you must be logged in:
Cheers, Ken
Jun 1, 2023 at 7:45 AM
