Check engine light on with Code p03040
82,210 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JRICHTER
Check engine light is on. Code p03040 camshaft sensor a bank 1. How do I locate and replace?
Sep 27, 2021 at 7:17 AM
SQM
  • 6,383 POSTS
The code:
P0340 - Camshaft Position Sensor A Circuit (Bank 1 Or Single Sensor)
This code gets triggered when ECM is unable to detect the cam position sensor.
It can be due to a faulty sensor, the circuit short to the ground, open circuit, not getting enough voltage, damaged sensor.
I have attached the basic diagnostics for that code.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
See diagrams below for the location of the sensor.
Sep 27, 2021 at 2:08 PM
