Where is the camshaft sensor located?
140 MILES • 2.2L • 4 CYL • 2WD • MANUAL
J THE CHEVY GUY
Hello. I'm trying to locate the camshaft position sensor. Everything I've looked up says it's by the oil pressure sensor but there is nothing there is it possible this vehicle just doesn't have one. Thank you for your time.
Mar 7, 2022 at 4:01 AM
  • 110,248 POSTS
They didn't use a camshaft position sensor on these in 1994. By chance, are you referring to a crankshaft position sensor?
Let me know what is happening with the vehicle. For example, it won't start because there is no spark to the plugs
I will watch for your reply.
Mar 7, 2022 at 10:56 AM
J THE CHEVY GUY
Thank you, Joe. I already replaced the Crankshaft sensor and am going to replace the other one, but I guess not. Thank you again.
Mar 7, 2022 at 11:15 AM
  • 110,248 POSTS
You are very welcome. Are you still having problems? If so, let me know what is happening. Also, if there are issues, here is a link that explains how to retrieve diagnostic trouble codes. It doesn't require a scanner.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know if there is anything I can do to help.
Take care and please feel free to come back anytime in the future. You are always welcome here.
Mar 7, 2022 at 12:18 PM
J THE CHEVY GUY
Mar 7, 2022 at 12:29 PM
