camshaft sensor location
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WILLIAMSTRISHA
  • 11 POSTS
Where is the camshaft sensor location on my car?
Jul 24, 2016 at 11:27 AM
SATURNTECH9
  • 30,869 POSTS
It is on the right front side of the engine.
Jul 24, 2016 at 12:29 PM
WILLIAMSTRISHA
  • 11 POSTS
I have looked everywhere for it and still do not see it.
Jul 24, 2016 at 12:37 PM
SATURNTECH9
  • 30,869 POSTS
They only give the location they do not give me a location graph on its location.
Jul 24, 2016 at 12:43 PM
SATURNTECH9
  • 30,869 POSTS
See if this helps.
Jul 24, 2016 at 12:48 PM
WILLIAMSTRISHA
  • 11 POSTS
I have that picture also but I still do not see it on the car thanks for your help.
Jul 24, 2016 at 12:51 PM
SATURNTECH9
  • 30,869 POSTS
I just read on a Cadillac forum about moving the coolant tank out of the way to get to the sensor. Maybe the tank is blocking your view.
Jul 24, 2016 at 12:58 PM
WILLIAMSTRISHA
  • 11 POSTS
It is possible my problem from the start is that it will run fine then I will park it and it wont start. spayed starter fluid in it it will start then die. I am not sure if it is the fuel pump or not but did read it can be the sensor.
Jul 24, 2016 at 1:03 PM
SATURNTECH9
  • 30,869 POSTS
Are there any codes in the computer? usually with a bad sensor it will set a code p0340 or a similar code. Also usually a bad fuel pump wont have those symptoms usually when they fail they do not cool down and start. Unless you smack the gas tank while cranking the engine sometime they will free up temporary.
Jul 24, 2016 at 1:07 PM
WILLIAMSTRISHA
  • 11 POSTS
I have a thing on the battery so I can undo it it had a security problem where I had to take the key out and wait three minutes so we did that to reset it sometimes, but the check engine light has never come on for anything. my brother checked for codes and none showed up, but that could be from disconnecting the battery.
Jul 24, 2016 at 1:13 PM
SATURNTECH9
  • 30,869 POSTS
You should borrow your brothers code reader and when the no start happens check for codes. When it does not start is the security light on solid or blinking with the key in the run position?
Jul 24, 2016 at 1:26 PM
WILLIAMSTRISHA
  • 11 POSTS
Best I can remember it flashes all the time.
Jul 24, 2016 at 1:37 PM
SATURNTECH9
  • 30,869 POSTS
If the anti theft kicks in you will lose fuel supply.
Jul 24, 2016 at 1:41 PM
WILLIAMSTRISHA
  • 11 POSTS
So should it be flashing or not ?
Jul 24, 2016 at 6:52 PM
WILLIAMSTRISHA
  • 11 POSTS
I've got a code now it's driver 3 p1660 any help?
Jul 26, 2016 at 7:50 AM
SATURNTECH9
  • 30,869 POSTS
Sorry I didn't get the email alert Iam not sure about the security light it doesn't give me information about the state of the light .It says it will say on the display when the fuel get disabled because of the security system.when it doesn't start see what the actual fuel pressure is and if you have fuel injector pulse.Also that code is for the radiator cooling fan nothing to do with starting.Are you having trouble with your radiator cooling fan?
Jul 26, 2016 at 1:48 PM
WILLIAMSTRISHA
  • 11 POSTS
Not that I know of got the camshaft sensor in and it started after a while I drove it to work today and now it's doing the same thing like it's not getting enough gas
Jul 27, 2016 at 4:18 AM
SATURNTECH9
  • 30,869 POSTS
Alright same advice check the actual fuel pressure and for injector pulse when it doesn't start.
Jul 27, 2016 at 5:33 AM
WILLIAMSTRISHA
  • 11 POSTS
We checked the fuel rail when it dont start and only get a few drops of gas
Jul 27, 2016 at 5:57 AM
SATURNTECH9
  • 30,869 POSTS
Does the fuel pump have power and ground to it when this happens?
Jul 27, 2016 at 6:10 AM
WILLIAMSTRISHA
  • 11 POSTS
How would I know without dropping the tank
Jul 27, 2016 at 6:12 AM
SATURNTECH9
  • 30,869 POSTS
Back by the tank there is a inline connector the connector is marked with letters for the terminal locations you want terminals A and B grey is power and black is ground ground will be ground always.Grey is only power while cranking the engine or the engine running.
Jul 27, 2016 at 10:35 AM
