Camshaft position sensors
110,000 MILES • 3.0L • 2WD • AUTOMATIC
KRBIAS
does this model have one or two sensors, if 2 where is it?
Jan 23, 2020 at 6:56 AM
  • 110,248 POSTS
There is one. Here are the directions for replacing it. The attached pic both correlates with the directions and shows the location of the sensor.
First, here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Here are the specific directions for your vehicle:
__________________________________
2004 Saturn L Series V6-3.0L VIN R
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Camshaft Position Sensor Service and Repair Procedures
PROCEDURES
CAMSHAFT POSITION (CMP) SENSOR REPLACEMENT
REMOVAL PROCEDURE
pic 1
1. Turn the ignition OFF.
2. Disconnect the camshaft position (CMP) sensor harness connector.
3. Remove the knock sensor 2 pigtail from the attachment clip.
4. Remove the CMP sensor attachment bolt and remove the sensor.
INSTALLATION PROCEDURE
pic 2
1. Install the knock sensor 2 pigtail clip to the CMP sensor if installing the new sensor.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the CMP sensor by gently pushing into place and install the attachment bolt.
Tighten the camshaft position sensor bolt to 8 N.m (71 lb in).
3. Insert the knock sensor 2 pigtail to the clip.
4. Connect the CMP sensor harness connector. Push the connector in until the lock position is felt, then pull back to confirm engagement.
Jan 23, 2020 at 12:05 PM
