Camshaft position sensor replacement
120,124 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DANY81413
I need to replace my camshaft position sensor on my car it has a 3.5L engine. Do i need to remove anything else to get to it?
Jun 27, 2016 at 12:58 PM
good morning
Remove the power steering pump. Refer to Power Steering Pump Replacement (LZ4/LZE/LZ9) (See: Steering and SuspensionSteeringPower Steering PumpService and RepairPower Steering Pump Replacement).
Disconnect the camshaft position (CMP) sensor electrical connector.
Remove the CMP sensor bolt.
Remove the CMP sensor.
Inspect the sensor O-ring for wear, cracks, or leakage if the sensor is not being replaced.
Jun 27, 2016 at 9:05 PM
DANY81413
Thanks and how do i remove the power steering pump?
Jun 28, 2016 at 12:35 AM
  • 55,845 POSTS
please start a new questions for this
Jun 30, 2016 at 12:12 PM
