Camshaft position sensor P0024
160,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
LACY MORRIS
  • 6 POSTS
When I replace the camshaft position sensor and I take the camshaft position sensor out is it supposed to have oil on it?
Mar 2, 2020 at 12:11 AM
Good afternoon,
Yes it is. The sensor goes into the block.
What is the original issue?
Mar 2, 2020 at 4:13 AM
LACY MORRIS
  • 6 POSTS
I've had problem after problem with this vehicle. When I first got it I had fuse box problems where it was over heating the fuse box and frying my fuses under the hood. Then the head gaskets had to be replaced. Then they replaced the motor with a used motor. I just replaced the alternator about a week ago. Then the vehicle started stalling and having problems shifting gears. It was using excessive amounts of gas too. I put an obd2 scanner on it and it came up with the code of P0024.
Mar 2, 2020 at 4:47 AM
STEVE W.
  • 15,404 POSTS
If you have a code P0024 it actually means the sensor is working and it detects that the camshaft is in a position that the ECM doesn't expect it to be at that time. Attached are the items that can cause that code to set on your engine.
A very common cause for this code is low or dirty oil as it causes the oil control valve to the phase control to stick or bind and the camshaft phaser doesn't move properly and you get this code. I would probably do an oil change if it's been more than 3-4000 since the last one, clear the code and see if it returns.
It can also be caused if the oil control valve has an issue where it isn't applying the correct pressure when selected, that can be caused by a piece of dirt or sludge blocking the screens on it or a faulty valve. Testing it is easy if you have a test meter. You unplug the oil control valve for that cam and test it for it's resistance. You want between 9.4 and 10.4 ohms of resistance if the valve is good. This won't tell you if it's plugged though, for that you need to remove it and see if there is a problem.
As for the oil on the sensor, yes that is normal because it is inside the engine next to the timing gears.
Mar 2, 2020 at 4:48 AM
Just to add what Steve said, I have found the dirty oil as the most common issue. I pressure flush the oil system to get all the dirt and debris out of the system and have great success with this repair.
Mar 2, 2020 at 5:01 AM
LACY MORRIS
  • 6 POSTS
Thank you. The oil does need to be changed, it is actually about 500 miles until the next oil change. Which I plan on doing tomorrow along with a full tune up on the vehicle. I changed the camshaft position sensor and it seems to be doing a whole lot better.
Mar 2, 2020 at 5:06 AM
Good, keep us updated.
Mar 2, 2020 at 5:10 AM
LACY MORRIS
  • 6 POSTS
Okay, so I haven't seen my check engine light come on the entire time I've had my vehicle (2 years) and I have had all these problems going on with it.. what could be a possible reason as to why it's either not coming on or not working?
Mar 6, 2020 at 4:57 AM
Did you get the oil system flushed as we discussed? Lack of maintenance is the major cause for this issue.
Mar 6, 2020 at 5:04 AM
STEVE W.
  • 15,404 POSTS
Watch the dash when you turn the key on, not to start, just on. The light should come on then go off as part of the bulb check. If you don't see it come on it could be blown or even missing, or it's possible there is a deeper reason. With that code the light should have come on.
Mar 6, 2020 at 7:05 AM
