Camshaft position sensor location
300,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MICHAEL COWART
  • 9 POSTS
I can't find the camshaft sensor location.
Nov 17, 2019 at 9:27 PM
Hello again,
You had for the crank sensor on the other post but now you have the cam sensor.
I attached the location and pictures for you.
1. Remove the camshaft position (CMP) sensor.
1. Disconnect the electrical connector.
2. Remove the bolt.
3. Remove the sensor.
2. To install, reverse the removal procedure.
Nov 17, 2019 at 9:56 PM
