where is the camshaft position sensor located?
160,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
ONEDART2MANY
I having a hard time finding the sensors location on my 1.4 l turbo version of the car.
Feb 12, 2025 at 8:13 AM
STEVE W.
  • 15,418 POSTS
It's sort of hidden on that engine. You have to remove the air intake box on top of the engine. Then you remove the oil separator and under that is the cam sensor. What code do you have that makes you think it's an issue? When was the timing belt last changed?
Feb 12, 2025 at 9:51 AM
ONEDART2MANY
I can't remember the codes of the top of my head, it was on my friends code reader, but three of the codes said camshaft position sensor, everything else I saw pointed to that location, but I couldn't find any real sources, that 3rd picture is exactly what I was feeling under there thank you so much.
Feb 12, 2025 at 9:59 AM
STEVE W.
  • 15,418 POSTS
You are welcome. If you think of the code(s) post them.
Feb 12, 2025 at 3:16 PM
ONEDART2MANY
I can't get my ratchet to grab the bolt it's at a weird angle how to I get to it, I've taken off some hoses and I can't get to it it's almost like I need the engine out.
Feb 13, 2025 at 8:49 AM
STEVE W.
  • 15,418 POSTS
I use a swivel socket or a short extension with a wobble drive and a short socket for the odd angles.
Feb 13, 2025 at 9:30 AM
