Codes P0345 and P0349, where is the Camshaft Position Sensor “A” Circuit (Bank 2) located?
122,000 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
SCHMITT14
I am getting code P0345 and P0349. The code indicates Camshaft Position Sensor “A” Circuit (Bank 2). I believe there are 4 of them, I'm just not sure which one is sensor a bank 2.
Dec 14, 2024 at 8:13 AM
  • 110,251 POSTS
Bank 2 is on the driver's side of the vehicle. I attached two pics below. Bank 2 sensor A (1), is highlighted in picture 2 below.
To access these, remove the cover at the top of the engine. It's held on with two nuts. See pic 3 below.
Let me know if this helps.
joe
Dec 14, 2024 at 2:06 PM
