first thing you have to do is check the VTC solenoid to see if it is working or has a plugged screen, then have a mechanic check for a stretched timing chain. after replacing both sensors then have a mechanic put them in sync with the crank sensor as this must be done with a scanner. it is like setting timing but you need a scanner to do it.
Images (Click to enlarge)
Oct 10, 2020 at 2:24 AM
