Will not start after removing and reinstalling camshaft position sensor
175,444 MILES • 3.7L • V6 • 4WD • AUTOMATIC
DAN STOCKER
  • 6 POSTS
I removed camshaft sensor then turned over motor while it was removed now when new one installed won't start. did I throw off timing by turning motor over?
Feb 28, 2021 at 7:21 AM
  • 110,251 POSTS
You shouldn't have done anything to the timing. Can you tell me why it was removed? Have you retrieved any diagnostic trouble codes? Is there still spark and fuel getting to the engine?
Here is a link that covers the most common causes of a crank no start condition. Take a look through it and see if it helps in any way.
If it was running with the old one, see if reinstalling it allows the engine to run. You could have gotten a bad sensor.
Take care and God Bless,
Feb 28, 2021 at 9:19 AM
DAN STOCKER
  • 6 POSTS
hard start cranks 3 to 5 seconds. check engine light on first said crankshaft sensor then multi cylinder misfire main 2 bank. changed plugs, coil packs, still hard start check engine light still on will not erase. motor seems to run great. next scan says o2 sensor changed, check engine light still on still hard start. next scan says fuel injector and coil packs, spark plugs 02 sensor, again my fuel pump comes on i can hear it even sitting for days. go out push valve on fuel rail gas comes out haven't tested for pressure yet. have seen on net it could be camshaft sensor,temperature sensor or mass flow sensor. so i got those on the way here. also bought injectors it also has new throttle body.Any suggestions. thanks for your help.
Feb 28, 2021 at 9:59 AM
DAN STOCKER
  • 6 POSTS
also bought an ECM from Flagship one put it on plug play it would barely run.
Feb 28, 2021 at 10:06 AM
NICKOLAOSF
  • 69 POSTS
HI DAN STOCKER,
We can help you with this information.
first i would like for you to put back engine control module, crank sensor and start all over.
this time you must scan and retrieve codes.
Let us know what happens and please upload pictures or videos of the problem.
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
I am glad to help you, If there is anything else we can help you with please contact us again. Thank you for choosing 2CarPros.
Cheers, Nick
Feb 28, 2021 at 11:00 AM
DAN STOCKER
  • 6 POSTS
yeah, already did. i have scanned about twenty times always something different. it was po300 as primary fix done crank sensorpo335 done got it but can't erases codes. crazy po300 random misfire already replaced fuel pump. maybe it runs great but light is annoying after do repairs.
Feb 28, 2021 at 1:15 PM
DAN STOCKER
  • 6 POSTS
cheap parts maybe it? has got new coil packs, new plugs, but ECM says no codes stay light stays on.
Feb 28, 2021 at 1:18 PM
NICKOLAOSF
  • 69 POSTS
I have send some. Check out the diagrams (below).
it sounds like you have a issue with your PCM (power control module).
Please run down these guide and report back.
Cheers, Nick
Feb 28, 2021 at 1:32 PM
NICKOLAOSF
  • 69 POSTS
sorry i added them.
Feb 28, 2021 at 1:33 PM
DAN STOCKER
  • 6 POSTS
thanks for diagram. got any more for 2007 Nitro 3.7?
Feb 28, 2021 at 2:50 PM
NICKOLAOSF
  • 69 POSTS
what are you looking for is it the same issue?
“Please start a new question” for the different or new issue and include the link. https://www.2carpros.com/questions/new
Cheers, Nick
Mar 1, 2021 at 12:52 AM
