Where is the Camshaft Position sensor located?
170 MILES • 2.4L • 5 CYL • 2WD • AUTOMATIC
NATASHABETTINA
Camshaft Position sensor location.
Sep 21, 2022 at 2:26 AM
  • 110,248 POSTS
On this vehicle, there are two. If you look at pic 1, it shows their locations. I circled them.
As far as replacement, the intake needs to be removed. I attached the directions needed to replace them. Because you need to remove the intake, I would recommend replacing both. Make sure to get a good-quality sensor. You don't want to do it twice. LOL
Sep 21, 2022 at 11:20 AM
