Camshaft position sensor?
250,000 MILES • V8 • 2WD • AUTOMATIC
JAMES891004
I have a red code for camshaft position sensor changed it when you first cranked truck runs good start going down the road it starts knocking and loses power.
Nov 21, 2022 at 12:15 PM
  • 110,248 POSTS
Is the code still present? Also, what was the code so I can look further into possible causes of it and what we should check.
The idea that you hear knocking has me concerned. Is there any indication that there could be an oil pressure concern? Are there any strange odors or smoke from the exhaust when this happens? I'm questioning a couple of different things but need the code you have. Also, if the timing chains have ever been changed.
One other question. Which V8 do you have?
Nov 22, 2022 at 12:44 PM
JAMES891004
Yes, the timings been changed not too long ago but I'm going get the other info to you shortly.
Nov 23, 2022 at 2:19 AM
  • 110,248 POSTS
Thank you for the update. I look forward to hearing the codes. Let me know whenever you can.
Also, I hope you have a great Thanksgiving.
Nov 23, 2022 at 11:59 AM
