Where is the camshaft position sensor located?
166,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
LOVEYSNWA
I can't seem to locate the camshaft position sensor. Help
Jun 23, 2023 at 1:20 PM
  • 110,248 POSTS
The camshaft position sensor isn't mounted on the engine. Actually, the sensor is located within the distributor and is comprised of a hall effect switch and a camshaft driven 6 bladed shutter plate. I attached a pic below showing the hall effect switch.
Let me know if that helps. Note, if you check at a parts store, they may refer to it as a pick-up coil/sensor.
See pic below.
Jun 23, 2023 at 3:04 PM
LOVEYSNWA
I need help locating the camshaft position sensor. I asked this same question, but I got the liters wrong it's a 3.8 not a 3.6. V6. please help.
Jun 26, 2023 at 9:42 AM (Merged)
