Bad vibration and rattle sound when accelerating
2014 VOLKSWAGEN JETTA
100,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
WESTWORLDER
Replaced camshaft position sensor because my check engine light was on and that was the error code given. My car also has a bad vibration and rattle sound especially when I accelerate. Changed sensor and still no change. What should I do next.
Oct 19, 2018 at 6:38 AM
  • 110,241 POSTS
A rattle can be caused by many different things. Can you tell approximately where the noise is coming from? Also, read through this link. It discusses the most common causes of engine rattles.
https://www.2carpros.com/articles/rattle-noise
See if anything in the link is helpful. Let me know what you find or if you have other questions.
Oct 20, 2018 at 9:33 AM
