I hit a rock or something. Immediately afterwards my car began to whistle when you first start it and my check engine light came on. My brake pedal also went soft and it seems as though I have no brakes. The engine also went into EPC mode. The code brought up read mass air flow sensor, fuel mixture too lean, vaccuum leak. The break lines are fine, and I replaced the spark plugs. It seems as though the engine is missing. I unhooked the battery cable and it did nothing except turn the light off. HELP! thanks
Aug 23, 2009 at 9:16 PM
