Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Camshaft
Camshaft Sensor
Location
Code P0365, camshaft position sensor B, bank 1 location needed
2017 FORD F-150
60,000 MILES • 3.5L • TURBO
JOSE0918
MEMBER
1 POST
Having trouble find camshaft position sensor for a code P0365 in sensor B, bank 1. Any images helps. Thank you.
Apr 4, 2021 at 3:40 AM
Experienced Mechanic
Good afternoon,
I attached the code description and possible failures.
It is for bank1 sensor 2 exhaust which is the one closest to the exhaust manifold. Bank 1 is the passenger side of the engine.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
I also attached the connector diagram for you to test to be sure there is a reference voltage to the sensor.
Images (Click to enlarge)
Apr 4, 2021 at 5:30 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
