camshaft position sensor relearn?
100,000 MILES • 2.0L • 4 CYL
MEOW571
  • 5 POSTS
replacing camshaft position sensor. Does the computer need to relearn the new position sensor?
Nov 15, 2025 at 9:17 PM
STEVE W.
  • 15,418 POSTS
It shouldn't need to have anything done other than changing it. What is the reason for changing it?
Nov 16, 2025 at 4:28 AM
MEOW571
  • 5 POSTS
we got the error code that told us it was the B side,I don't remember the number we did this Saturday and right now I don't have access to the car
thanks
Nov 16, 2025 at 8:38 PM
STEVE W.
  • 15,418 POSTS
Do you know the actual code you have? Asking because many times it is not a bad sensor but either wiring or an internal issue with the cam phasers.
Nov 16, 2025 at 11:30 PM
MEOW571
  • 5 POSTS
I don't know the code.
Nov 17, 2025 at 7:51 PM
STEVE W.
  • 15,418 POSTS
What are the symptoms other than the CEL being on?
Nov 18, 2025 at 4:35 AM
MEOW571
  • 5 POSTS
Will send more info when I'm with the car in a couple of weeks. Thanks for the help.
Nov 18, 2025 at 5:55 PM
STEVE W.
  • 15,418 POSTS
No rush. We will be here.
Nov 19, 2025 at 9:34 AM
MEOW571
  • 5 POSTS
Car is a Hyundai Elantra 2.0 Sel. The code is: P0017. Changed cam sensors & couldn't zero out code. Could it be the timing chain?
Nov 29, 2025 at 2:36 AM
STEVE W.
  • 15,418 POSTS
It could be but I doubt it because it is only the single sensor and no other codes. As such I would say to pull the exhaust cam VVT actuator oil control solenoid, be sure it isn't plugged with trash or sludge. If it isn't and the oil is clean then test the solenoid to be sure it operates. I generally just use a 9 volt batter but you can use the 12 volts as well, you just want to see if it works. If it tests OK then it is probably the VVT sprocket that failed and is locking the cam in the full retard position so the sensor sees the cam out of time compared to the crank. About the only repair is to replace the sprocket and if you are already there you might want to do a full timing chain replacement.
Nov 29, 2025 at 4:56 AM
