camshaft drive gear?
297,000 MILES • 4.2L • V6 • 2WD • MANUAL
CHEFDAVE 855G6
Can't find one.
Jun 11, 2023 at 5:48 AM
  • 110,248 POSTS
I suspect you are referring to the sprocket which the timing chain runs on. I found several. Take a look at pic 1 below. That is one example.
This may help you locate what is needed as well. The OEM part number is E8DZ6256A
See pic below.
Jun 11, 2023 at 11:17 AM
CHEFDAVE 855G6
Not the sprocket it's the distributor camshaft drive gear part # f7zz6255aa.
Jun 12, 2023 at 3:06 AM
CHEFDAVE 855G6
Jun 12, 2023 at 3:35 AM
  • 110,248 POSTS
Wow, I see what you mean. I did find a couple of things online for you to check out. The second one listed below seems the most promising.
https://www.fitinpart.sg/index.php?route=product/product&product_id=7579789
https://aftermarket.supply/ford/f7zz6255aa.html (See pic below)
How bad is the original one?
Jun 12, 2023 at 2:24 PM
