Camshaft timing marks in the wrong place?
200,000 MILES
DAVID TODD
  • 13 POSTS
Put number 1 cylinder at TDC and the dow pins are in the wrong place. how do I fix? This will be on the right bank.
Aug 3, 2022 at 3:04 AM
  • 55,542 POSTS
Are they 180 out? you turn the crankshaft one time, and they should line up. If this is not the case, I have found the camshaft and crankshaft timing marks in the diagrams below, also check out the link:
https://www.2carpros.com/diagrams/kia/sorento/2003
Aug 3, 2022 at 9:38 AM
