The VVT actuator solenoid is on the left they are the same for all of the positions. The VVT cam sprockets on the right are different however, they have different range of motion and timing provisions. If you are talking about the sprocket actuators that is likely the problem.
Run a compression test on those three, I expect there is some valve damage if the chain broke while it was running.
Images (Click to enlarge)
Nov 4, 2019 at 3:06 PM
