car not starting
242,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
NGWANAMOHUBA
The car was not having power, driving very slow, we parked it, for 2 months. we replaced spark plugs. after we replaced the plugs the car could not start, it was cranking.when we try to diagnose the problem it fault of camshaft sensor A, and inter-cooler hose. We replaced the camshaft sensor the car still not starting.we took out the battery and recharged it and put back, the car is still not starting. Please advice as to what could still be the problem. Thank you. Regards, Olivia
Aug 24, 2019 at 3:47 AM
  • 55,748 POSTS
So does the engine crank over and not start or not crank over? Do you have a security light flashing when you try to turn in over?
These guides will help get us started:
and
Aug 26, 2019 at 7:43 AM
