Camaro zl1 2020 code saying p0420?
37,000 MILES • 6.2L • V8 • TURBO • 2WD • MANUAL
SOLO987
Well I have been having problems with knock sensors. On both bank 1 and 2 and now I got a code saying p0420. And I have headers and a cold air intake on it.
Sep 5, 2025 at 10:33 AM
  • 55,709 POSTS
Did you remove the catalytic converters? if so this will be the reason for the trouble code:
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Please let me know.
Sep 6, 2025 at 9:29 AM
SOLO987
Yeah I did. Im running kooks headers
Sep 6, 2025 at 9:34 AM
  • 55,709 POSTS
If you don't have cats you will have this code and the engine will not run at optimum performance. Believe it or not the engine is made to run at the best performance from the factory. Unless you plan a bunch of expensive engine and computer work is it best to leave it stock.
Sep 7, 2025 at 1:54 AM
