Turn signals are not working
155,000 MILES • 3.6L • V6 • 2WD • MANUAL
IGENIUS92
  • 205 POSTS
Hi i have the v6 3.8L engine. My turn signals don't work,the hazard lights work both front and rear. i see the lights blinking on the cluster but when i turn on the turn signals on the cluster it doesn't even light up. the front and rear turn signals don't light up either. Can anyone help?
Jul 21, 2019 at 8:19 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's Turn/BU Fuse #2 of the I/P fuse panel which is located behind the left side of the dash. In the diagrams down below I have included a wiring diagram of your vehicle's Exterior Lighting Circuits as well as a diagram and callout of your vehicle's I/P Fuse Panel. Here is a link for you to go to, if needed, for how to check a fuse.
Please go through these diagrams and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 22, 2019 at 6:54 PM
IGENIUS92
  • 205 POSTS
Got it thanks! Actually i found the issue it was the blinker relays underneath the steering wheel were bad then i got some from the junk yard and now it works! Thank you!!
Jul 23, 2019 at 3:34 AM
  • 55,628 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jul 26, 2019 at 3:35 AM
2CP-ARCHIVES
  • 4,540 POSTS
Right blinker doesn't work all the time...sometimes just the light will go on but not blink. Occasionally it happens on the left side as well but not as often. Any ideas?
Thanks in advance,
John
Jul 26, 2019 at 3:37 AM (Merged)
  • 110,248 POSTS
John,
It sounds like you have a bad flasher. It is under the dash near the steering column. Try that to see if that fixes your problem. It is a cheap part.
MIKEDZNUTZ
i have a 1994 camero and for some reason the turn signals dont work or the high beams but my hazards do
D5NUKE
  • 61 POSTS
Your turn signals are on a different fuse from the hazard lights. Check the fuse its the 20 amp one on the top row.
94CAMARO
have replaced the blinker relay, the 20 amp fuse in the panel, the flasher fuse under the dash next to the driver side door, and blinker switch in the steering column ans still no blinkers. the hazards work but the turn signals wont work is there another fuse or relay i missed
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse #2 (20 amp)if that fuse and the signal switch and bulbs are good along with relay flasher than it must be a wiring issue, that is all thats left on the signal circuit.
RDCAIN60
My inside indicator lights are not lighting up when using my turn signal. Also flashers are not working. Check the bulbs and they were good, checked fuse -OK , replaced flasher, still not working. Lights working on outside just not showing on dash panel lights? Flashers not working at all inside or out.
Jul 26, 2019 at 3:38 AM (Merged)
  • 110,248 POSTS
Do the interior lighs work with the 4 way flashers?
RDCAIN60
No the interior lights do not work with the flashers, I spoke to a friend who is a mechanic and he thinks I have a ground problem. I am still looking into that. Thanks for your help.
  • 110,248 POSTS
I have agree with him unless one went out then a couple days later, the other one did the same.
Let me know what you find and if you have other questions.
IGENIUS92
  • 205 POSTS
Will do thanks again
Jul 26, 2019 at 4:55 AM
