Cam shaftsensor
1991 PONTIAC GRAND PRIX
1,000,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
GARY CALLIES
Can you disconnect a camshaft sensor and drive?
Nov 16, 2016 at 3:00 PM
  • 31,937 POSTS
No. the engine requires the input signal from the cam position sensor to set ignition timing amongst other inputs.
Nov 16, 2016 at 4:36 PM
GARY CALLIES
Can you jumper the sensor out?
Nov 16, 2016 at 4:58 PM
  • 31,937 POSTS
no you cannot. the ECU needs the electrical impulse created by the sensor to feed data to the system.
Nov 16, 2016 at 5:22 PM
