Car keeps shutting off while driving. Can't find where the synchronizer is located in my vehicle.
Aug 5, 2023 at 4:25 AM
✓Experienced Mechanic
Are you referring to the camshaft position sensor? I don't believe this has variable valve timing. Also, I need to know if this is a V6 or a V8 engine.
Let me know that. Also, explain what is happening and if you know of any diagnostic trouble codes that are active.
