Where is the cam sensor located at on a the vehicle listed above V8 5.2?
May 16, 2019 at 10:42 PM
STEVE W.
✓Experienced Mechanic
Welcome back to 2CarPros. The CPS is on the front of the engine behind the front generator bracket. If you have a code for it I would look at the jumper harness first as the connectors get corroded.
Image (Click to enlarge)
May 16, 2019 at 11:31 PM
WIGGINS DONNA
MEMBER
May 17, 2019 at 12:01 AM
STEVE W.
You're welcome. What is the issue you are having?
May 18, 2019 at 12:34 PM
WIGGINS DONNA
MEMBER
Where would I find engine control relay on the 2005 Buick Rainier V8 engine 5.3
May 20, 2019 at 12:15 AM
STEVE W.
All of the engine power and control relays and fuses are in the underhood fuse and relay block. However there is not relay labelled as the Engine Control Relay.
