cam reinstallation, what are the torque specs for cams caps?
98,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ST1NGER
need torque specs for cams caps.
bolt torq sequence.
need timing mark placement.
Apr 14, 2024 at 5:28 AM
  • 110,248 POSTS
I attached the torque specifications and the timing mark locations below. Take a look at them and let me know if that is what you needed.
Once you release the tensioner on the belt, double check the marks to make sure nothing moved. Also, since this is an interference engine, I recommend turning the engine by hand several rotations to confirm there is no internal contact between the piston tops and the valves. If you feel resistance, don't force it.
If you need additional information, let me know that as well.
joe
Apr 14, 2024 at 1:01 PM
ST1NGER
just a note, 1st overhead cam type head short learning curve. thanks again
Apr 15, 2024 at 10:28 AM
  • 110,248 POSTS
You are very welcome. If you have a chance, let me know how things turn out for you. I'm interested in knowing. Also, if you have other questions, let me know.
Apr 15, 2024 at 12:49 PM
ST1NGER
did my reply include the questions on the cam riming marks and timing chain?
Apr 15, 2024 at 3:16 PM
  • 110,248 POSTS
No, I didn't see that info. However, I attached a pic below showing how they are aligned. Note: There are colored links on the chain that will align with the marks.
Take a look at the picture and let me know if that is what you needed.
See pic below.
Apr 16, 2024 at 12:09 PM
ST1NGER
head is back together marks lined up will torque everything today will prep block this afternoon your specs and diagrams, it was a whole easier. thank you for your time and consideration help will advise once back together and running.
Apr 19, 2024 at 4:35 AM
  • 110,248 POSTS
You are very welcome. Let me know how things turn out for you. I'm hoping everything goes smoothly for you.
Take care and have a good weekend.
Apr 19, 2024 at 1:34 PM
