Cam Position sensors?
6.0L • V8 • 2WD • AUTOMATIC
LARRY Q WILSON
What Cam Position (Brand Names) sensor does not require a relearn procedure?
Oct 27, 2022 at 6:43 PM
AL514
  • 5,700 POSTS
Hello, it doesn't look like there is any type of relearn procedure if you're just replacing the camshaft position sensors in service information. What kind of issues are you running into? Are the sensors still setting codes?
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Oct 28, 2022 at 2:28 AM
