Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Avalanche
Engine
Camshaft
Camshaft Sensor
Location
Cam Position Sensor
2007 CHEVROLET AVALANCHE
171,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
RLDAVID71
MEMBER
Coding P0011. Is the CMP on this engine located at upper rear of engine, passenger side, and only access is to remove the intake?
Aug 13, 2016 at 10:27 AM
HMAC300
Experienced Mechanic
no it's on lower leh side of motor see pic
Image (Click to enlarge)
Aug 15, 2016 at 12:31 AM
RLDAVID71
MEMBER
Thank you. I'd understood that location to be the Crankshaft position sensor.
Aug 15, 2016 at 11:34 AM
HMAC300
no crank sensor runs off of crank by the starter
Aug 15, 2016 at 10:44 PM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
